How to – Dell XPS 15 – Battery Replacement
Marque : Dell
I have just seen on Dell's support site a how to for replacing a battery of Dell XPS 15. The battery of this computer is embedded and the replacement requires opening the box. But the procedure is really straightforward. I have also searched a non-Dell place where one could buy a cheap replacement battery but unfortunately did not find any. The only I know is Dell and price tag is about $185 – which is pretty expensive.  http://www.cbatterie.com/dell-xps-15-batterie.html  ,
By the way, there is one procedure which I follow to extend the battery life of my computer. When it is plugged, I disable battery charging from the power options – (down right next to the clock or Fn+F3). Based on my prior experience this approach extends the battery life to years unless the battery has some fabrication defect.
- Réparer chargeur RYOBI 18v one+ (9 réponses )
 - Transforming Nursing Education with FlexPath Assessments (0 réponse )
 - Chargeur batterie gys 15 12 reste en 6 v et ne passe plus en 12 v (2 réponses )
 - Chargeur de batterie batium 12/15 gys ne charge plus (0 réponse )
 - Chargeur Black et Decker 14,4V ne charge plus -résistance grillée (0 réponse )
 - Power Box MSB7010 (6 réponses )
 - WILTEC Class Booster 430 – Batteries 12V et 24V (0 réponse )
 - Problème batterie lithium 14.4V - 1.5 Ah. Lumière éteinte sur le chargeur. (5 réponses )
http://www.batteries-boutique.fr/batteries.php/XPS_15+battery+DELL — johnxuster1984 2 pts
